Ignition is messed uP! :)
Old 02-05-2013, 01:56 AM
PortlandBlazers's Avatar
PortlandBlazers is on a distinguished road
Default Ignition is messed uP! :)
I can pull out the key while the car is running!
Thats not the main issue, though. I cannot turn the key to the full off position, so the car is always in accessory mode, which is pulling about 2.7 amps and draining my battery really quickly!
I've looked all over online and people have similar problems, but none with the exact same.
Do I just need to replace the ignition cylinder? Is that the same thing as an ignition switch? I saw something about replacing just the tumblers?
I'm really going for the DIY. I want to learn this stuff! Any good advice?
Big thanks in advance!
2003 6cyl 2dr 2wd
ps. Im looking for a few cheap interior parts(visor, defrost cover), any ideas?
Old 02-05-2013, 11:15 AM
richphotos's Avatar
sounds like your ignition cylinder is bad
As for interior parts, you can try Truck Parts and Truck Accessories for Chevy, GMC, Ford and Dodge Trucks from LMCTruck.com
or a u-pull it yard.
Old 02-06-2013, 12:50 PM
Thanks! Thats what I was thinking too...I just thought it could be possible that the wiring in the switch could be going wrong. You don't think that could be the case?
Old 02-06-2013, 01:44 PM
richphotos's Avatar
I doubt it, the wiring would not cause you to be able to pull your key out while its running, and it would also not cause a problem where you are unable to turn it to the off position.
biggpoppa3
12-18-2009 07:12 AM
91rustbucket
06-11-2009 04:27 PM
RSBlazer
02-24-2007 11:06 AM
dusted800
11-12-2006 04:28 PM
XBlazer01
03-12-2006 09:59 PM
Quick Reply: Ignition is messed uP! :)
