heater control question
Old 02-18-2013, 10:19 PM
Rumblur's Avatar
Rumblur is on a distinguished road
Default heater control question
I have a 2000 Blazer with the auto climate controls. My heat is not working, but both heater hoses are warm at the firewall. I am old school, I prefer to control the simple controls... could I change the computer control for a standard 3 **** mechanical controller?
Also - what is the the thing to do when you have both heater hoses warm, and no heat? (again, 2000 2wd 4dr computer climate controls)
Old 02-18-2013, 10:57 PM
Twip's Avatar
Twip will become famous soon enough
the motor for the blend door might have gone out. its pretty simple to check the motor. all you have to do is turn the car on, engine off. wait for all the beeping to stop and then turn the temperature from cold all the way to hot, or vise versa. if you listen carefully you should be able to hear the motor working under the dash. if not then you have your answer.
i dont know how hard it would be to switch it over from the automatic to the manual.
Old 02-20-2013, 06:31 AM
Rumblur's Avatar
Thanks Twip. This motor you're talking about, is it electric or vacuum?
waviaerith
05-22-2010 10:02 PM
jamies96
12-18-2009 09:05 PM
kota04sxt
12-10-2009 09:34 PM
The Beep
01-27-2009 10:11 PM
MudHawg
12-20-2005 12:56 PM
Quick Reply: heater control question
