Which rear end is in my truck????
Old 01-18-2007, 10:13 AM
alamantia's Avatar
alamantia is an unknown quantity at this point
Default Which rear end is in my truck????
I have a 1992 chevy K1500 blazer. It appears to be the stock rearend. It has 10 bolts around the inspection cover. Does that mean I have a 8.5" Ring gear with 30 spline axles? Does anyone know?
Old 01-18-2007, 11:11 AM
MNHawk's Avatar
Default RE: Which rear end is in my truck????
Look for the ID tag on the cover and the IDstamp on the outside of the Axle shaft. Most of these came with a DANA axle.
I will try to find the links I have for DANA information so that you can decode your axle.
Old 01-18-2007, 11:40 AM
blazin~kblazer is an unknown quantity at this point
Nice to see anouther k1500 blazer! i just signed up for this forum. Im also wondering what rear end i have in my 94. is it a posi or regular open?
Old 01-18-2007, 11:48 AM
MNHawk's Avatar
Try looking in the glove box and see if you can find the code for the Axle
here are some codes to cross with:
4x4, 10 bolt cover, 4.10 ratio GT5
4x4, 14 bolt cover, 4.10 ratio GT5
4x4, 10 bolt cover, 3.42 ratio GU6
4x4, 10 bolt cover, 3.73 ratio GT4
4x4, 14 bolt cover, 3.42 ratio GU6
4x4, 14 bolt cover, 3.73 ratio GT4
4x2, 3.08 ratio GU4
4x2, 3.42 ratio GU6
4x2, 3.73 ratio GT4
4x2, 4.10 ratio GT5
Happy Hunting
Old 01-18-2007, 11:56 AM
alamantia's Avatar
ORIGINAL: blazin~kblazer
Its a 3.42 GM 10 bolt for sure, I have never seen a 1500 seriesone with a DANA 14 bolt. Not saying they arnt out there, i just dont recal ever noticing. Ive seen 2500 series and 3500 series Tahoes with DANA's though...
Im just curiouls of the ring gear size and axle splines. It has an open carrier and I see a rebuiltGov-lok on ebay I was going to make a bid on, i just want to make sure I do indeed have a 8.5 ring gear and 30 spline axles before i bid, i know there was an 8.2 10 bolt rear but I believe thats for older GM cars and I have seen some 28 spline truck axles in teh past but i believe they were for older GM trucks...
Old 01-18-2007, 12:34 PM
Chevy Lover's Avatar
You can check your RPO code as MNHawk suggested, you can also check for a code on the right rear of the axle tube (might need some sandpaper to find it). I have changed my gearsets so often that I would have to pull the cover to be sure and do an inspection.
Old 01-18-2007, 01:05 PM
alamantia's Avatar
true true, thanks guys, i wasnt aware that RPO codes would tell you the difference between splines and ring gear diameters, i thought they just told ratio. i will look into it.
RED21
04-21-2013 11:12 PM
brino1
02-25-2011 08:05 PM
southernsteel87
09-11-2010 09:41 AM
zedartwo
12-18-2009 09:52 PM
ginobass
06-26-2007 02:39 PM
Quick Reply: Which rear end is in my truck????
