No start, manual security reset?
Old 02-12-2007, 03:02 PM
01extreme's Avatar
01extreme is an unknown quantity at this point
Default No start, manual security reset?
I have a 2001 Blazer xtreme p.o.s. 4.3L v6 2door. December, changed the key cylinder, then the truck wouldn´t start. Found out, there is a manual reset u have to do with shutting and opening the doors several times for the computer to establish communication with the new hardware. Well, everything was running well then. Now this morning, I get to turn the truck on, and it just turns and turns, a couple sputters but no start. Now I am thinking ignition module, switch, what else? When I turn the truck on I hear the pump hummm, then it just turns. No firing, what can cause this!!!
Old 02-12-2007, 07:54 PM
clays99blazer is an unknown quantity at this point
Default RE: No start, manual security reset?
Is ur security light on? If so try starting ur truck and if it doesn't start leave the key turned to the run position till the light turns off [10 mins or so] good luck mine does the same thing and I have to do it every other day
Old 04-13-2008, 03:50 PM
f1yrod is an unknown quantity at this point
can you remember the exact door process for the manual reset ??
spud-truck
12-27-2018 04:08 AM
2001blazer
04-19-2007 06:39 PM
nofear17bmx
01-14-2007 12:22 AM
FemmeVamp
12-08-2006 07:04 PM
57chevy
04-30-2006 12:08 PM
Quick Reply: No start, manual security reset?
