Sign in using an external account
Register Forgot Password?
Search
Closed Thread
Old 03-14-2007, 12:28 AM
speeddemon560 speeddemon560 is offline
speeddemon560 is an unknown quantity at this point
Default s10 2.2l mass air flow sensor
Hello. Does it make a difference if I use a ported mass air flow sensor that come off a 2.2l S10 on a 2000 4.3l blazer? Thank.
[size=3][center]2000 Blazer gettin' pimped
http://s168.photobucket.com/albums/u167/speeddemon560
My dash with Nu Image Platinum stuff.
Old 03-14-2007, 01:34 AM
20Blazer00 20Blazer00 is offline
Default RE: s10 2.2l mass air flow sensor
It can because the computer is expecting to see a specific amount of airflow and the 2.2L MAF might not have the flow needed to keep the computer happy...also connectors might be different....
Mark
2000 Blazer LS 4dr 4.3L Auto
1999 Grand Am 3.4L 4dr SE2 - Traded
2000 Honda Odyssey 3.5L 5dr Mini-Van
Old 03-14-2007, 09:11 AM
swartlkk swartlkk is offline
2009 GMC Yukon Denali
My Garage
When it comes to MAF sensors, you have to make sure that their frequency response is the same given an equal flow rate of air across the flow range the 4.3L requires.
1st thing I'd check is to see if the MAF sensor is even the same size as the 4.3L MAF. The 4.3L MAF is the same one used on the 5.7L v8. Are you replacing it in hopes of gaining performance?
Old 03-14-2007, 09:42 PM
Kordog Kordog is offline
The 2.2l does not use a MAF sensor, it uses a MAP sensor that senses pressure in the intake, where the MAF measures the air flow into the motor. The 4.3l uses both sensors.
Korey
2000 Blazer LT, 30X9.5x15 Dueler AT, Cold air intake, Magnaflow exhaust.
ASE Master Auto Tech.
Old 03-14-2007, 09:44 PM
Quote:
ORIGINAL: Kordog
Whoa. You just blew my mind. Thanks for the help.
Closed Thread
Tags
1999, 2001, 22, air, airflow, chevy, flow, location, maf, map, mass, problems, replacing, s10, sensor
Vendor Directory
Our Sponsors
Internet Brands, Inc.
